Fusion Support
Obliged to run the tool utility to repair Fusion360 quite often
8 REPLIES 8
Message 1 of 9
cpinatel
169 Views, 8 Replies
I am running Fusion 360, not commercial version on an iMac 2017 27"  i7 16gb ram and 1to ssd with plenty of space.
I am in learning mode, I started using it about two weeks ago.
I had in quite a few occasions the same issue and it is really annoying.
Quite frequently Fusion360 doesn't start after it claimed that the network was lost and I am in offline mode or after I did quit the application (carefully) I don't get a splash screen, nothing. Even if I wait a long time nothing happens.
I am obliged each time to run the supplied utilities tool to repair the application, this process is quite long and this is really annoying.
Can you help ?
Charles
8 REPLIES 8
Message 2 of 9
@cpinatel It would help the next time you are not able to start the product, before you do the repair, can you run Gather system info and attach the diagnostics logs.zip
Just to be sure, please make sure that the macOS is also up-to-date.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
Hi, thanks for your reply, Mac OS is up to date for the Ventura OS, 13.6
Message 4 of 9
Ok. Next time happens please send the logs.
Autodesk Fusion
Join Fusion Insider
Message 5 of 9
cpinatel
in reply to: cpinatel
It happens every day or so. Where can I find the logs ? I restarted and re ran the tests about an hour ago
Message 6 of 9
So in the service utility run the gather system info and it will generate zip files.
Autodesk Fusion
Join Fusion Insider
Message 7 of 9
Hello, enclosed are yesterdays files. I hope they can be useful to you.
Charles
Message 8 of 9
cpinatel
Hi, it happened just now again. I had a message (screen print enclosed) telling me that I was in offline mode although we had no internet cut (I didn't close Fusion yesterday evening), I then saved yesterdays' work just in case and closed Fusion 360, when I tried to restart it, same punition , it would not start.
I am running the tools application again now, but it is sloooow !  Each time a repair solved the problem, but I find it annoying.  It seems that the repair download a version of Fusion again and again.
Is there a solution to this ?  I read in another post that I wasn't the only guy in this situation.
Thanks in advance.
Charles
I am using an Apple iMac 27" i7 16gb ram, 1to ssd hd with plenty of free space.
Last Ventura OS, 13.6 and last version of Fusion360
Message 9 of 9
@cpinatel Here is what I am going to recommend and see what happens.
1. Close Fusion 360
2. Restart machine
3. Run a complete uninstall of fusion
4. Reinstall again
If you hit this issue again, we would like the log files
How to collect logs:
1. Go to the launch pad
2. Run Fusion service utility
3. Run gather system info
Attach the zip files here.
Autodesk Fusion
Join Fusion Insider
