Announcements
OBJ to STEP File Convert
asif.ahmed.cr7
Message 1 of 12
asif.ahmed.cr7
Hello, I have an OBJ file, I want to convert it into a STEP file. The current file is in mesh format. I uploaded it into fusion 360 and tried creating T Spline but it failed every time. I tried creating BREP, But converting into brep format I cant edit the mesh or do anything. I saw that reducing mesh size can make it to convert into T-spline. But I can't find any way to edit the mesh file. Pls, Help me to convert the file.error 1.JPG
Replies (11)
Message 2 of 12
asif.ahmed.cr7
It happens when i try to convert mesh to t spline
Message 3 of 12
g-andresen
try this
günther
Message 4 of 12
g-andresen
take a look at this
günther
Message 5 of 12
asif.ahmed.cr7
Can you tell me how to convert Triangle mesh to quad mesh in meshmixer ??
Message 6 of 12
dsouzasujay
Hi @asif.ahmed.cr7 ,
Fusion 360 is asking you to enable mesh workspace.
To enable it go to Your Name->Preferences->Preview Features and Enable "Mesh Workspace"
Then you should be able to see Mesh commands.
To Convert Mesh to BRep body, You need to be either inBase Feature(Video from 0:26 sec) or activate the Direct modelling(Video at 0:48 sec)
Video: https://knowledge.autodesk.com/community/screencast/4266cae0-5bd4-4aeb-bcec-b459bc936ab4
Edited: Just now saw your reply, saw you have already fixed enabled Mesh workspace
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 7 of 12
asif.ahmed.cr7
Thank you , I got the mesh tab but I want to convert it into step file so that it converts from a mesh file to solid-body/surface, What should I do?
Message 8 of 12
g-andresen
1. create Brep
2. File > Export > STEP
günther
Message 9 of 12
TheCADWhisperer
Can you Attach the original obj file here?
Message 10 of 12
asif.ahmed.cr7
The file is attached. I want to convert it into step format.
Message 11 of 12
dsouzasujay
You convert into BRep
  • In Fusion
    1. By Rightclick on Mesh body and Triangulate mesh.
    2. "Reduce" the mesh size from Mesh workspace
    3. Convert "Mesh to BRep"
    4. Mesh to Brep
  • In Fusion
    • By Rightclick on Mesh body and Triangulate mesh.
    • "Create Mesh Section"
    • From Mesh section create 2D sketch
    • Create solid body from extrude
    • Mesh Section & BRep
  • In Netfab & Fusion
    1. Convert Triangular Facets to Quad in Netfab
    2. Export as OBJ and Import the same file to Fusion 360
    3. Go to sculpt
    4. Convert Mesh to TSplines
    5. Attached: Part_Brep v1.f3d
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 12 of 12
asif.ahmed.cr7
Thanks for help.
