Announcements
Now fusion will not start up at all
oneturboneeded
oneturboneeded
I read it might be that having 2 monitors might be the problem, I unplugged the second monitor and now  get 4 pop up messages qt6gui.dll and 3 others that are similar. I reloaded fusion no change.ugh sad.
RajkumarIlanchelian
@oneturboneeded @See if the below helps.
1. Make sure Fusion is not running in task manager
2. Restart your machine
3 Go to add/remove programs
4. Select Autodesk Fusion and Modify
This will launch the service utility
5. Run the repair Fusion from here
Now does it help to launch successfully?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
oneturboneeded
no the same message pops up
oneturboneeded
ok so i uninstalled for a 3 time and this time it worked
