Announcements
Not Responding on Start up
zummerz36BQQD9
Message 1 of 12
zummerz36BQQD9
I just downloaded Fusion 360 with a personal use license but when I try to open it, it doesn't respond. I get the splash page and then it opens the window with a grid work space, and the tool bar never shows up and it just locks up. I'm running a G7 laptop with a Navidia graphics card. I've tried updating my graphics drivers and it still won't work.
Replies (11)
Message 2 of 12
RajkumarIlanchelian
@zummerz36BQQD9 Can you please try the following?
1. Go to task manager and make sure Fusion is not running
2. Restart your machine
3. Go to add/remove programs
4. Select Fusion 360 - Modify
5. This will launch the Fusion service utility
6. Run the reset fusion - Does this now help to launch Fusion?
If you are still seeing the issue, go back to the service utility and run the gather system info. Please attach the two zip files that it generates.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 12
zummerz36BQQD9
tried this, still doesn't work. I still just get this and the same "not responding"
Message 4 of 12
RajkumarIlanchelian
@zummerz36BQQD9 @Can you run the gather system info and attach the zip files here?
Autodesk Fusion
Join Fusion Insider
Message 5 of 12
zummerz36BQQD9
Father System Info? do you mean my device specifications?
Processor Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz 2.59 GHz
Installed RAM 32.0 GB (31.8 GB usable)
System type 64-bit operating system, x64-based processor
Message 6 of 12
zummerz36BQQD9
Oh, wait you mean gather system info. that's not working either. When I try I get a loading bar for like 2 seconds and then the service utility manager just closes and I don't get any zip files from it.
Message 7 of 12
RajkumarIlanchelian
My bad, go to the service utility and run the Gather system info. This will generate two zip files.
Autodesk Fusion
Join Fusion Insider
Message 8 of 12
zummerz36BQQD9
 that's not working either. When I try I get a loading bar for like 2 seconds and then the service utility manager just closes and I don't get any zip files from it. I've tried it with the program running and with it closed and it won't work.
Message 9 of 12
RajkumarIlanchelian
@zummerz36BQQD9 OK. Lets try to get the logs in a different way. (Also, do you have other Autodesk products installed on your machine?)
Need two kinds of log files:
1. Application logs
  • C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\(Alphanumeric Folder)\logs  (Look for all *.log files.)
  • C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\logs  (Look for all *.log files. Logs here when login is unsuccessful.)
2. Service logs
Id Services Log File exists on version 2.0.15775 or newer:
  • Windows OS: %localappdata%\Autodesk\Identity Services\Log\IdServices.log
Autodesk Fusion
Join Fusion Insider
Message 10 of 12
zummerz36BQQD9
Ok I think I got the right files
Message 11 of 12
zummerz36BQQD9
Oh wait, I think I got it working. I unplugged my drawing monitor and it loaded through fine.
Message 12 of 12
RajkumarIlanchelian
@zummerz36BQQD9 Glad to know this is now working but can you give some more info on the "drawings monitor"? Are there any update drivers for those if there is software involved?
Autodesk Fusion
Join Fusion Insider
