What do I see?:
When did this start?
- I restarted my PC for the first time in a while, then this started happening, so might have done updates or something that caused this?
What did I try?
- Updated Radeon drivers to 20.2.2 and then 20.4.2. As per a suggestion on the forum, the drivers were installed as fresh installs, not updates.
- Windows Update is up to date
- Deactivated Antivirus, Firewall and Pi-hole (just in case it started blocking an important domain)
- Uninstalled Fusion
- Restart
- Run Clean Uninstall Script
- Restart
- Verified clean uninstall with manual procedure
- Clean registry with CCleaner
- Restart again
- Install Fusion as Admin (also did this whole procedure without as admin)
- launched Fusion with and without as admin
Once this procedure worked and I spent the day designing. The next day I was met with the same Not Responding again.
System
- Ryzen 2600
- Radeon RX570
- 16GB RAM
- Windows 10 (up to date)
- Radeon drivers: 20.4.2 (also tried 20.2.2)
I tried almost everything that made sense suggested to others, but I hope I missed something silly and easy, or my logs shows something useful to someone else! Logs attached as zip, hope thats fine
