Announcements
Not recognizing imported step file holes, inspect tool shows length only
aston8CNTF
Message 1 of 14
aston8CNTF
I have an imported step file from other CAD software. There are circular holes with chamfer on a curved surface, but Fusion is unable to recognize the circle as a circle. When using inspect tool, the circle on either sides of the hole only shows length, not radius. However, when clicking on the hole surface, inspect tool does show radius. How can I measure the radius of the circles and the chamfer? Thanks!
Replies (13)
Message 2 of 14
aston8CNTF
BTW - I can calculate radius from length and manually add that with leader in the drawing. But I am still unable to create center marks for the holes, which is needed to place dimension between 2 circles.
Message 3 of 14
jhackney1972
You will need to zip up the STEP file and attach it to your post for others to be able to troubleshoot your issue.
John Hackney, Retired
Message 4 of 14
aston8CNTF
Got an error:
Correct the highlighted errors and try again:
The attachment's lem_hp_top.step content type (application/octet-stream) does not match its file extension and has been removed.
It is a step file... How can I fix it?
Message 5 of 14
jhackney1972
As I said in the first post, you must zip the file up to attach it.  Certain files must be zipped to be attached and this is one of them.
Message 6 of 14
aston8CNTF
Here is an f3d file since the step file was accepted by the forum. Odd...
Message 7 of 14
aston8CNTF
Oh I see! Thank you. Here is the zipped step file.
Message 8 of 14
jhackney1972
Fusion 360 cannot measure either of the hole feature, and return a diameter, because the features are not circles, they are ellipses. A circle cut on a curved surface will create ellipse edges.  In the attached screen capture I have cut a section across the midpoint of one of these holes and then sketched a line (blue) between two of the points on the middle ellipse.  If you look close you will see the dark edge line below the sketched line.  It is curved, where the blue line is straight.  This is why you get a Length measure from Fusion 360.
Message 9 of 14
aston8CNTF
Thank you very much! It was likely extruded from a surface tangent to the curve, which created eclipses on the curve, but still creates a circular hole. In this case, is there anything I can do to to mark the hole center in the drawing? Or is the only option to create a sketch in the drawing and guess the center? Thanks again!
Message 10 of 14
jhackney1972
You could probably get by pretty well by using the Sketch command in the drawing environment.  It will snap to keypoints of the elliptic holes and you can dimension to them.
Please mark you post as solved if you are satisfied with the answer.
Message 11 of 14
aston8CNTF
Thank you very much for the detailed explanation!!!
Message 12 of 14
TheCADWhisperer
If you Project the edges to a sketch in the modeling environment - they do not match standard drill sizes (I checked in mm and in inches).
You might create them slightly larger (to a standard size).
Message 13 of 14
aston8CNTF
Thank you. Interestingly, the diameter I set to was exactly 5.7mm, instead of 5.692. Though it was a great suggestion, and I have changed the holes to standard drill sizes. How did you project to a sketch and get recognizable circles? I projected on an offset XY plane and it showed length only still.
Also, although I am able to calculate the diameters and distances, I am still unable to create a center mark. I tried to create a cross in drawing sketch, but the snap feature really does not allow the line to start at where I want it to be. Is there a way to create center marks? Thank you!
Message 14 of 14
TheCADWhisperer
@aston8CNTF wrote:
1. Thank you. Interestingly, the diameter I set to was exactly 5.7mm, instead of 5.692. Though it was a great suggestion, and I have changed the holes to standard drill sizes.
2. How did you project to a sketch and get recognizable circles? I projected on an offset XY plane and it showed length only still.
1. Does this mean that you created the original file (in some other CAD software)?  The reason I ask - is I saw other anomalies, but it would take me too long to describe to someone who did not create the original geometry.  If it was you who actually created the original geometry and then exported as STEP to bring into Fusion - I think that we can quickly resolve the anomaly.
2. I projected the edge (result is spline in sketch), constructed perpendicular construction lines and then sketched my circle.
