not posting nc file since update
bigbrad73
bigbrad73
I am having problems since the update with fusion not posting nc file to disk or coming up in the editor. Anyone else having the same problem?
seth.madore
This is a known bug. There are two workarounds:
1) Right click on the Setup and select "Create NC Program". Select your post and your directory, post as expected.
2) Create a subfolder on your USB and select that location at posting time.
There is a bug where posting to root directories isn't working. The above 2 options are what we have for the time being.
Seth Madore
Having same problem in 11/2021, no nc files.  Thought I was doing something wrong.
This gets around it - thanks!
seth.madore
@Anonymous are you fully up to date on Fusion? This issue was resolved rather quickly after it was discovered..
Seth Madore
