Running on a Windows 8.1 machine with all current updates, Fusion 360 version 2.0.4860, standard logitech wireless mouse (also occurs with internal mouse pad and buttons on laptop).
I have been having this problem lately with Fusion 360, everything works really well for designing until I want to export a body to STL. I have the design the way I want it I can right click everything until I right click the body and "Save as STL" the stl export window opens I select OK and the window closes and nothing happens. I should be prompted with the save directory but it will not open. Then the open to right click in the browser disappears. I can no longer right click and a small dot shows where I clicked in the browser but nothing happens.
I have used the clean uninstaller and reinstalled and the problem goes away for 1 or 2 projects and then comes back. I don't know where the bug is occurring but it does not occur on a different computer with the same project.
Frustrating to say the least.
UPDATE:
As I hit the submit button I realized that I have been saving my STLs to a network directory and that computer requires a log in to access the shared directory. If that directory is not available (ie you need to log in) Fusion will not prompt you to log in it will just bug out and hide the export directory selection window (browse folders window). Once you reconnect to the network folder the browse folder selection dialog will display. Hopefully this helps someone else out in a similar situation.
