Fusion Support
Noob - need help modelling complex ring
1 REPLY 1
S_Hasan1_22
87 Views, 1 Reply
I am looking to design this ring would there be a way to do this parametrically, it is designed to look like the impression of a knotted rope over the ring, with the open ends running into the walls of the intersecting lines. I honestly don't know where to start so if someone can point me in a direction or help even a little that would be greatly appreciated.
Talha Hasan
1 REPLY 1
Slight correction of terminology, but a big difference IMHO.
You have already designed the ring. Now you want to model it.
Go through the timeline and look at each feature to see what it does.
Very gently modify the only partly constrained and dimensioned sketches.
The small fillets at the end of the timeline were only applied for rendering. For continued modeling those would be removed. What is attached and shown in the images is just the base geometry. The pattern will add another layer of difficulty.
Peter Doering
