Announcements
Non linear section view In Drawing. View from one direction only.
LiveLover
LiveLover
Hello!
I draw section view. And section line has angles. Is there some special name for such section views?
At this picture my intent was to make 1 section that cross 2 holes. I was surprised that  section became longer than the main view.
Can we make a section view that does not contain red segment?  (View in one direction only)
Like SolidWorks does
Thank you!
HughesTooling
You need to make sure all changes in direction are exactly 90°, if you are of at all you get the elongated section. You will also get a problem if you have 2 collinear lines in the section lines. See this thread for more info.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
If i load your image into Fusion and sketch over it the vertical lines look out.
Mark Hughes
