I'm trying to add some holes to a body using the Hole tool in the "From Sketch" mode, but the default direction of the holes is down (toward the bottom origin plane) and the body I want to make the holes in is up above the sketch plane. Fusion 360 will not let me flip the direction of the holes to fix this. I can't drag the arrow past the 0 point like I normally could for an extrude. I can't change the depth to a negative value. There is no option to "flip" the hole direction. Fusion just assumes holes always go down, and there seems to be no fix.
Please add a "flip direction" option to the hole tool when in "from sketch" mode!
