No pattern instances could be intersected with the original body. Try adjusting the pattern settings, or changing the selections.
jejepierce
jejepierce
I keep getting this error when trying to mirror features across a midplane.
jhackney1972
Please attach your model so the Forum users can see what your issue is.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
danny.pike
I've just hit this, too.
For those coming across the same bug, my workaround is to select the object by clicking in the Browser "Objects" menu.
Do NOT click on a face of the object.
Although the command will seem to accept clicking on the face as a way to specify the object, you will get this error when you try to apply the pattern / mirror operation. This appears to be a bug in Fusion.
gokul_b211133me
Community Visitor
Community Visitor
I came across this.Go to sketch edit and try to apply pattern
pbtimebomb
Community Visitor
Community Visitor
i was trying to pattern an emboss on a vase. i used the timeline to highlight the body was how i worked around it. your post gave me the idea.
sgutierrezPYSN9
Community Visitor
Community Visitor
You can try doing the following.
bhavani_sankuratri
Hello @jejepierce
Did the information provided by sgutierrezPYSN9, danny.pike help you and answer your question? If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information. If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
Bhavani Sankuratri | Community Manager
