Announcements
No passes to link
ghost24SBH9Z
No passes to link
ghost24SBH9Z
I don't understand what I'm doing wrong but it creates an empty toolpath for me. Can anyone help me?
Replies (11)
seth.madore
Can you please export your Fusion file with a Setup and toolpath attempts?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
ghost24SBH9Z
Done
seth.madore
What's the expected result; use the 11mm tool to clear out the tool slots in the part?
Seth Madore
ghost24SBH9Z
Doesn,t work
seth.madore
Right. But what I'm asking is: Are you looking for that tool to machine those slots, with a toolpath that is shown in the above image?
Seth Madore
ghost24SBH9Z
Works with a 9mm cutter. Is there no way to use an 11.5 cutter?
But I also changed the slot
seth.madore
Still didn't answer my question, so I'll assume the answer is "yes, I want that slot to be machined with that toolpath shown in your image"
Your selections should be:
And your settings should be:
1) Compensation Radius Allowance set to .1
2) Lead distance and radius set to .1
3) Vertical Lead turned off (optional)
File attached
Seth Madore
ghost24SBH9Z
How did you create the entry points?
seth.madore
Seth Madore
ghost24SBH9Z
Ok but the sketch that you see at the bottom what is it?
ghost24SBH9Z
