Fusion Support
No option to merge?
5 REPLIES 5
112 Views, 5 Replies
No option to merge?
I want to join the flat surface to the rounded one, but there is no merge anymore. How could I do this?Compass Right Arm SS.png
5 REPLIES 5
HughesTooling
in reply to: 90308251
If they are 2 separate bodies you should use combine not merge. Or are you trying to blend between the 2 bodies?
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Looks like you might need to clean up the workflow on the body with the flat face as there are some non planar surfaces or is this intended?
Mark Hughes
TheCADWhisperer
@90308251
in reply to: HughesTooling
I am trying to blend between the two bodies
TrippyLighting
That could be achieved a variable radius fillet.
Peter Doering
