Announcements
no more dependencies can be added
fwindels
fwindels
No more dependencies can be added to the blue lines
An den blauen Linien lassen sich keine abhängigkeiten mehr hinzufügen, in den Skizzen: "Magnete-Bits" und "Magnete-Bohrer"
Replies (9)
jhackney1972
I for one need you to clarify what you are trying to do in this model that is giving you the error you are stating.
John Hackney, Retired
fwindels
I want the blue lines to be black.
fwindels
The blue lines are not fully defined, but no more dependencies can be added.
Die blauen Linien sind nicht voll definiert, es lassen sich aber keine Abhängigkeiten mehr hinzufügen.
jhackney1972
You were on the right track with the construction line but it needs to be an arc and at the other ends of the tangent lines.  I believe you will understand it better if you move the two sides lines of their position and let the constrains move them into their fully constrained position.  The Screencast will explain.
fwindels
with your solution the distance betwen the endpoints of the two lines are 8,677 mm and not 8,5 mm
jhackney1972
You can have one or the other.  You can have a fully constrained sketch or the 8.5 dimension due to your geometry.  if you want the 8.5mm dimension, ignore the unconstrained sketches and move on, they are not going to move.
HughesTooling
Here's how to constrain and keep the lines parallel. I made the screencast before the last 2 posts. First it shows the angle done the way @jhackney1972  did it, then I show a couple different way to constrain with a line coincident with the arc centre. I should point out you should sketch only one then pattern the slots as a feature rather then sketch patterns.
Mark
Mark Hughes
Owner, Hughes Tooling
g-andresen
so it works with the recommendation of @HughesTooling
Screencast
günther
fwindels
Thanks, I know the circular pattern, the circles all have different distances
