Announcements
No more capture position feature ? Part changing position when exporting or copy/pasting - ... since last update
chrisQX8DX
Message 1 of 10
chrisQX8DX
hi there,
now that i'm back working on my project after the file corruption bug is solved i noticed another odd feature:
I have a part i modeled inside of larger project assembly. The part was at a 1° angle. Once i roughed out the shape i exported the part to another file, removed the 1° angle and continued to model the part and add other parts to it. Now i want to export the finished part again to another file for manufacturing but when i open the exported part it's back slanted at 1°. So i tried creating a new design and used copy/paste new but again the part comes in at 1° angle. So i thought maybe i forgot to capture position (although that would have surprised me since i've been modeling on that part for a week now and surely would've noticed. But all was alright in the original file. And then i noticed that whenever i move sth i don't get a capture position button at all anymore, even in a fresh file when i create an object and move it i don't have a capture position checkbox anymore nor the capture postion buttons in the toolbar.
Maybe the feature just changed/moved in some update ?
Can't share the file publicly but happy to do so with someone from Autodesk support. But as i said the capture position feature is missing altogether for me now even on fresh designs.
Intel Macos 15.1.1
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. Whenever needed or whenever i can i will attach a file for troubleshooting. If no file is attached i will always try to explain as clearly as possible and if needed or helpfull provide illustrative screenshots. When i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
Accepted solutions (3)
Replies (9)
Message 2 of 10
davebYYPCU
Capture Position is a Assembly / Component command, when History is active.
Might help...
Message 3 of 10
chrisQX8DX
yes @davebYYPCU , i have history enabled and i am moving a component but get no capture position option.
Intel Macos 15.1.1
Message 4 of 10
Rushikesh.kadam
@chrisQX8DX I am able to see both the capture position checkbox and capture position buttons in the toolbar.
As you are observing the issue on a fresh file, is it possible to record a video on a fresh file and post it here?
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 10
chrisQX8DX
Thanks @Rushikesh.kadam i didn't see that i had objects and not components selected in the dialog. So the capture position is back.
However i still have the wird problem of that part that when exported from a flat position ends up rotated at 1° when exported or copy/pasted to another fresh file. It's not ahuge issue since i can just rotate it back but it's a strange behaviour.
SOmehow i can't seem to add a screencast inline here. Here is the URL: https://autode.sk/3yUBwx1
Intel Macos 15.1.1
Message 6 of 10
TrippyLighting
You should never rely on a position capture feature in an assembly to position components.
Message 7 of 10
chrisQX8DX
@TrippyLightingusually i don't, i usually model without design history or assemble components. I just wondered wether the capture position thing somehow bugged this file export that's why i thought it was related. I don't understand why the exported or copy/pasted file takes on a postion it once had in another file where it came from. Does this behaviour in the screencast seem normal. I haven't run into this before and i worked my usual workflow.
Intel Macos 15.1.1
Message 8 of 10
HughesTooling
Are you just exporting a component or the whole design? When you export a component using right click and Export the component's origin is used not the design's origin. You can get around this if you isolate the component you want to export, right click the top node in the browser and Export.
Mark Hughes
Owner, Hughes Tooling
Message 9 of 10
chrisQX8DX
aha, i did not know that. i thought when you right click export it takes the position it has in the main deisgn file it is in.
Intel Macos 15.1.1
Message 10 of 10
chrisQX8DX
actually still battling with this from time to time. The Isolate>Export trick doesn't really work for me since it doesn't allow to export as a fusion file but just external formats.
It just seems weird not ot be able to freeze the component position and have an invisible transform attached to it that gets scrapped when you import the part into another design.
Intel Macos 15.1.1
