Announcements
no models displayed when in the design workspace
stangbladeworks
stangbladeworks
I want to start designing a new pallet, when I opened my old file to copy over some of the models I noticed they do not display in the design workspace. The do appear fine in the manufacture space. This is not the case for all my files, it seems just this one is causing issues.
I'm Hoping this is just something obvious I am overlooking. Any help is greatly appreciated. I
jhackney1972
Can you attach your model?  Make sure all components are displaying in the Design Workspace.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
stangbladeworks
Thanks for the reply,
It looks like at some point I must have accidentally enabled a section view that cut off everything. Once I disabled it all is good. Unfortunately I figured this out only after posting here.
