Bend angle labelAs you can see in this screenshot, I used to be able to click on the 'Leader' text button, and create labels for my bend angle. I would click on the leader button, click on a bend center line and the "UP 90.000 R0" would appear parallel to the line. I could then drag it out and position it with a leader line as shown.
This no longer works. Clicking on the bend center line, just gives me a leader line, with no bend angle text. Just a text dialog box where I can enter text manually. It just seems to have happened overnight... One day it worked fine, The next day not at all. I don't think I had even restarted Fusion, so I don't know it was a software update that caused the problem or what.
This is obviously very important because it makes a big difference whether the bend goes up or down. It is sometimes difficult to tell based on how the flat pattern was created which way it should go.
Also, in the course of trying to figure out a work around, I noticed that the 'Bend Identifier' table also won't let you select a bend center line. I've never used this function before, so I don't know if it ever worked, but I can't get it to work now.
I've tried creating just a very simple sheet metal pattern to see if perhaps it was something about my model but that won't work either.
I would appreciate any help with this issue.
Jody
