Announcements
No guess of obvious units ?
gamelife4dns
gamelife4dns
Please see attached picture. Not sure it needs any comment 😉
So, if "x0" and "y0" are mm, what unit is:
x0^2 + y0^2  ?
sqrt(x0^2+y0^2)  ?
First is mm² (or mm^2), second is mm.
Is there a simpler way for writing :
sqrt(( x0^2 + y0^2 ) / 1 mm^2) * 1 mm ?
Obvious to me, not so much for Fusion.
Steve
g-andresen
No, Fusion does not know the unit mm^2.
The current best solution for such things is to make the lenghts for the calculation unitless beforehand.
günther
gamelife4dns
Sorry Günther, did you see ma screen capture ?
Fusion actually accepts this as is :
( sqrt(( x0^2 + y0^2 ) / 1 mm^2) ) * 1 mm
No, it doesn't accept "mm^2" but it accepts (and mandates) " / 1 mm^2" to remove the unit of the previous expression "(x0^2 + y0^2)".
SQRT() function seems to only accept unitless values.
And no, a length (or an area) is never unitless. If the sides of a triangle are in "mm" the hypotenuse is also in "mm" (the above formula).
BTW, there is a quite huge list of units to select in the parameter dialog, even for area and volume, but none are useful. "Acre", "liter", "gallon" what for with Fusion ? We need "mm^2" or "mm^3" !
The question remains : Is there a simpler way for writing :
 (sqrt(( x0^2 + y0^2 ) / 1 mm^2) ) * 1 mm ?
Steve
