No edges where patterned part meets existing model
f.schuldt9JK4X
Observer Observer
f.schuldt9JK4X
Observer
Observer
I am running into an issue, where I start with a basic shape, create a pattern, which intersects the model at multiple times, but there are no edges where the pattern intersects with the model. The only edge existing edge is where the pattern parent intersects the model. How can I get the edges? I want to add fillet, which seems to require edges.
Attached is a screenshot and the f3d file.
HughesTooling
The patterned bodies are not joined, you'll need to use a combine to make a single body.
And after combine
Mark Hughes
Owner, Hughes Tooling
f.schuldt9JK4X
Observer
Observer
This works perfect. Much appreciated.
HughesTooling
JFI. You could have done this with less features if your extrusions where in a different order. If you extrude the pillars first then the rectangular floor then pattern the floors they will automatically join.
Then pattern. File's attached, sizes are wrong so you need to edit the sketch and extrusions ect.
Mark Hughes
