I could well be misunderstanding this announcement from the March 2021 "what's new" document, but I am not seeing this behavior in the current macOS version of Fusion 360:
Improved! Auto-fit window after scaling sketch on first dimension
Works only if “Scale entire sketch at first dimension” is turned on in Preferences
The preference option “Scale entire sketch at first dimension” enables you scale the entire sketch when you place your first dimension on it. If you have this option turned on, than you’ll be glad to know that Fusion 360 will also Auto-fit the window to sketch after it has been scaled on first dimension. This should make it easier to see the sketch as a whole, if your scaled sketch turns out to be bigger than your viewing area, or conversely too small for your viewing area.
I do have "Scale entire sketch at first dimension" turned on, and sketches do rescale proportionately around the first-applied dimension. However, there's no zooming or "fit to window" going on; the zoom remains as it was before the first dimension was applied.
Is this feature something I have to turn on, or is it supposed to be a normal part of "Scale entire sketch at first dimension" now?
