Newbie has "lost" sketch
salesMUBBN
salesMUBBN
I have been building up an enclosure for electronics PCB and nitice I need to move the supports for the Motor to the right. (See attached image). The problem is that I can select extruded parts of but cannpot locate the sketch that created it. I started this as a rectangle on the bottom of the box that was extruded to a solid block then had parts extruded out of it.
If I can find the original sketch then I can simply move it 1mm right.
hamid.sh.
Right click on the extrude in timeline. If you see Edit Profile Sketch you have your answer:
If you don't see that option probably you have extruded directly from a face and there is no sketch to edit, and you'll have to use another method (e.g. Modify > Press Pull):
By the way, 3 sketches in "Base (1)" are hidden. Aren't you looking for one of them?
Hamid
salesMUBBN
Thank you
I found the sketch and it was way up under the main component and not in the "Base" here I thought I created it.
I can grab the ractangles representing the extrusion but cannot move them a set amount, only freehand. In the original I did a parallel align to the position along the edge I wanted it. Can that position be changed somehow or deleted and done again?
If I try to align to a new position I get an error "Failed to solve, please try revising dimensions or constraints"
davebYYPCU
You are not following Rule 1.
You have blue lines in that / those sketches.
Depending on what's there, and what you want to do, it should be as simple as edit the dimension value, (in fully defined sketches).
Might help....
g-andresen
With active sketch, you must first project the main body into the sketch. To do this, call up the corresponding menu with the shortcut P and select the body (option Body) or the option Elements and confirm the selection. Then you can orientate the sketch by the magenta lines with conditions and/or dimensions.
günther
salesMUBBN
Looks like I need quite a few fundamentals sorted.
Is there a video training course that will cover proper dimansioning and constraining sketches and also how to do projections. I would like to do things likje project component bodies from PCB to say the lid or edge for cutouts and supports etc.
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
