Can Autodesk please reconsider bringing back the use of Fusion 360 in a browser? I found this topic out, through searching about Fusion 360 for ChromeOS. Why isn't this still available?
I'm amazed by the lack of support for ChromeOS/Chromebooks in general, as I have a 2017 i7 Pixelbook. This device is certainly not lacking in hardware.
The beauty of working from a browser, is that it isn't dependent on OS and hardware specs. It also isn't dependent on only one physical device to be used.
Cloud computing is absolutely the future!
Google does it now with Stadia, and OnShape has been doing this.
What happens when that one computer dies on me? I would have to get it fixed immediately or purchase a new (most likely expensive) computer. All this, while I'm still not able to continue with my design. And that's the enemy .... DOWNTIME!
I'm also not interested in remoting into that one physical computer, just because it has Windows on it. Plus it's rather silly, if you ask me, to be tied to one computer. Please tell me, does it make sense to have two computers running at the same time, just so I can have the flexibility I'm desiring? I still have the same potential issue as explained above. It goes down, I'm out of luck! I don't even want to think, that if I have to travel, I'm relying on my physical Fusion 360 computer to stay up and running.
Or, give us the flexibility with a browser based solution. Independent of OS, independent of physical hardware specs. If my computer goes down, I can hop on another device (desktop, laptop, Chromebook, smartphone, etc.), login and be on my way. Let us access our projects through something like Google Drive; all users get 15 GB for free. Offer a free certain amount of GB, save files in the cloud, on the same Autodesk server used to run Fusion 360.
So again, I please hope Autodesk reconsiders a browser based solution.
Thank you.
