Announcements
New Tool Library fails to display. Produces a solid black window with "Tool Library" printed at top of window.
alanhooker
alanhooker
Any one working on Mac OS 12.5.1 know why the NEW Tool Library fails to display?
The old Library also fails to display the graphic of the tool & holder, but the tool entries do display.
Tomorrow the old library goes away, and I have not found a solution to this problem.
I am using a MacBook Pro Retna early 2015 running the latest version of  Mac OS. 12.5.1
I have tried running the Repair function. Tried reloading the Fusion 360 program. Updated the OS.  Same results.The helpful guys at AutoDesk are stumped. I am thinking Fusion 360 called a function in the OS and fed it bogus parameters. Maybe that function is turned off?
When I go to the tool Library I get a new window that is solid black with Tool Library written at the top.
I can close the window and go back to working in Fusion 360 so the program is not crashing. It just doesn't display the tool table. I don't see this problem on my MacAir.
Regards, T
seth.madore
Hmm, I was not able to reproduce this on my MBP (2022) running 12.5.1
Can you share any screenshots of what you are seeing?
Seth Madore
alanhooker
You want a screen shot of a perfectly black screen?
You must be kidding?
Regards,T
seth.madore
I spoke with the Tool Library team about this, who I understand you've been working with? Apparently you're the only one they've encountered who is dealing with this issue. Not much to go on at this point, I'm afraid...
Seth Madore
