New extrude set to 'New Body' still joins??
What I'm reporting here may be related to what has been reported elsewhere, although this seems to be a bit different.
I wanted to post a screencast but the Screencast app tells me I need 6GB of available disk space to record—I have way more than that, so I'm not sure what the story is, so I'll have to put it in words.
I have two concentric circles, first I extrude the 'ring' between the outer and the inner circles to create a hollow cylinder. Then I extrude the inner circle to created a solid, smaller cylinder, but first I choose 'New Body' as the operation type because I want to have two bodies. Even if I select New Body, Fusion will still join the two cylinders.
My current workaround is to hide the first cylinder before extruding the second, then unhide.
This looks like a bug because no matter what you select it always joins, which means the New Body operation type is completely redundant.
