Nested Polygon Constraint Issue
I'm running in to issues with constraining a series of nested hexagons that I'm trying to uses as the bases for loft profiles. I'm starting with the inner most hexagon, defining it with a circumferential radius and defining one side as horizontal/vertical . For all other 'outer' hexagons in the nest, I'm constraining one side as horizontal/vertical and coincident to the intersecting corner of the 'inner' hexagon below. This appears to work fine for the first 3 or 4 hexagons but fails to fully constrain any additional hexagons (as shown below). My attempts to further constrain the hexagons fails with an over constrained error. I also don't appear to alter or move any of the non-constrained sides as the program returns an over-constrained error even though visually it indicates the lines are not fully constrained.
I believe this issues is causing issues with my lofting profiles starting which works for the constrained hexagons but runs in to problems at the first non-constrained hexagon. It is behaving similarly to a non-closed profile error that I've run in to the past, with fusion creating 1 additional node point (beyond the 6 corners of the hexagon) at the mid point of one of the hexagon sides. To create the lofting profiles, I'm projecting one of the hexagons onto a new sketch on an offset plane and offsetting the projected hexagon to form a shell.
