Need Help Using Sweep Tool
kepp.andrews
Message 1 of 12
kepp.andrews
Does anyone have written or video instructions to use Fusion 360 Sweep Tool as this guy does with Solid Works. See video for example of what I'm trying to do. (Complex use of Sweep Tool)
https://www.youtube.com/watch?v=2af2tCQFwUs
Replies (11)
Message 2 of 12
davebYYPCU
When ever he says Curves, Fusion calls it Project to Surface, and select Vector direction.
There are more efficient ways to construct that, but as yours is complex, would need some idea of what is complex.
Message 3 of 12
TheCADWhisperer
Message 4 of 12
kepp.andrews
Here is 3 of 6 pics and a gif
Message 5 of 12
kepp.andrews
Here are last three files and one gif. I can sort of get this to work by making two planes and crossing them with a thickness of .001 and then use that as the path. It works, but I can't get Projection to project from one plane to the other plane because it is not actually one plane. It is several planes after the line has been extended. I can already tell this is going to be hard to decipher. Hopefully someone can point me to a tutorial that will allow me to use Projection to accomplish what I'm trying to do with Sweep. If there is a better way to do this then please let me know. Thanks in advance.
-kepp in keller, tx
Message 6 of 12
kepp.andrews
Last three files
Message 7 of 12
kepp.andrews
Message 8 of 12
kepp.andrews
To be clear I would like to project the blue line onto the visible plane and then have one new blue line to use as a path for the Sweep command.
Message 9 of 12
TheCADWhisperer
@kepp.andrews wrote:
Last three files
Message 10 of 12
kepp.andrews
Here is the .f3d file
Message 11 of 12
jhackney1972
I will give it a go to try and interpret what you desire.  Screencast will show the process, model is attached I used.
John Hackney, Retired
Message 12 of 12
kepp.andrews
Thank you John!!
