NC Program disappear after post process in fusion 360 after new update and post to my setup sheet has stopt workin.
For the NC Program problem, you've unchecked Create In Browser.
Mark Hughes
Owner, Hughes Tooling
Hello, @rickard2DDXE.
When you post process setup or operations directly, Fusion does not create NC Program by default. This behaviour was done explicitly for people, who used to use old post processing dialog. If you want to create NC Program and keep it in the browser tree, you can select option "Create in browser" at the bottom of the dialog. Also you can explicitly create NC program by using button "Create NC Program" near "Create Setup":
About "post to my setup sheet has stopt workin". Could you provide more details about the issue, I don't understand it.
Thank you!
Thanks that solved bote problems. 😄
