Navigation bar is off the bottom of the screen
davemelton
davemelton
Appreciate if you could offer any assistance in recovering the navigation bar usually located at the bottom of the screen. In the attached screenshot, you can see if I hoover my mouse right at the very bottom of the screen at popup still appear showing the various options of the navigation bar i.e; orbit, pan, zoom, etc but the bar appears to be covered by the white desktop
I'v tried
1 = view menu> show/ hide navigation bar (+toggled on & off the other view option several times with no luck)
2 = resetting the default layout
3 = toggled off "do not capture design history"
4 = reset panel customisation & reset all toolbar customisation
5 = shutdown and restarted computer and fusion 360 countless time
6 = deleted root file "Neutron Platform" from autodesk folders and restarted
7 = switching between full screen, partial screen docked, streached
8 = changed the native screen resolution
notwithstanding all of the above I still can't get the toolbar to appear
(Lastest fusion with all updates, mac high sierra 10.13.6 with all updates)
thanks in advance
davemelton
have complete uninstalled and reinstalled f360 as per Autodesk recommended procedure for a fresh install.....still have the same issue !!!
productbakery
I have the same/similar problem.
I am using windows 10, on a laptop with an external monitor attached (2 screens).
When I use fusion on my laptop screen then the nav bar works as expected.
When I use fusion on my external screen, (and my laptop screen is configured to be below the external screen), then when I click something on the nav bar (yes I can see the nav bar), then when the pop up list is too big, it is not shown.
Probably it wants to show it on my laptop screen which is below the external screen, but it doesn't.
erichskj
Community Visitor
Community Visitor
I have same issue, and i have same setup with external monitor as you describe.
