I'm gonna need a second pair of eyes on those log files. I took a look but wasn't able to pinpoint anything specific. In the error report you submitted, it says you're running Windows 8, are there any pending Windows updates to install?
Have you tried eliminating all unnecessary background process, like anti-virus software? Sometimes a good test to eliminate background processes is to start the computer in safe mode (with networking enabled). The easiest method I know to do this is in the msconfig command:
1. Use the Run window. To do that, simultaneously press the Windows + R keys on your keyboard or launch CMD.exe
2. Then, write msconfig in the text field and press Enter or OK.
3. In the Boot tab, check Safe Boot and Network
4. After restart, kill any unnecessary processes in the Task Manager (CTRL + SHIFT + ESC)
5. Retest the procedure
I haven't heard this issue reported widely, so I think there may something really specific on your system that is leading to this. I will circle back after I get any updates on my side.
Let me know if this helps! I look forward to your reply.
Nathan Chandler
Principal Specialist
