Names of bodies in a design are changing next time I open the project.
Not sure what's going on, This started happening about two weeks ago. A project I'm working on designing different components (bodies) are named accordingly after I'm finished with each component or at a stopping point where I need to design the next component to make sure each part has clearance. Anytime I open the program and the saved file from last session on same project, The components I created or modified during my last session will have changed their names back to Body#### or switch names with other components. For example I just opened the program, and a part I had named for a sensor cover front and back and a couple screws to hold the parts together were named Screw1 and Screw 2. But as I just opened the program, One of those screws are named sensor cover front, The other one is named Body3850, The one I had named Sensor cover front has changed it's name to a old component I had deleted.
Clearly something is going on with my files from the time I save and close the program and open the program to start working on project again. It's getting a little ANNOYING having to go through and waste time correcting the names each time I open the project instead of working on the project.
I've given no permission or access for anyone else to work on my files but since I cant keep MY FILES on MY DEVICE I dont really have full controll over my files. I've cleared the Cache Data, Corrected the names early yesterday and closed the program waited about 10 minutes to open the program and everything was correct but after that I actually did more work on the project, saved it lastnight then opened it today and that's when I noticed the names of everything I worked on lastnight had changed From the time I saved and closed the program
[post title shortened]
