Announcements
My plane head loft is in 2 colors instead of 1
thanhbinhle0509
thanhbinhle0509
I'm building a airplane but when I create the plane head, It's in 2 colors instead of same color like in the tutorial. I do not know if this is normal or not and does it affect the part when I go to the manufacturing process. Thank you for all the help!
g-andresen
Reverse is your friend for single faces or stitch and reverse for all faces
günther
jeff_strater
Also, you can turn this effect off completely.  By default, Fusion colors the "front" and "back" sides differently, because sometimes it matters.  But, if you don't care, turn it off, by turning on the "Disable Surface Normal Display":
Jeff Strater
Engineering Director
TrippyLighting
Is there a reason you have disabled the timeline ?
thanhbinhle0509
Cause if I don't do that, it will be really difficult for me
