Announcements
My Fusion 360 isnt opening
meghanavidyadhar23
meghanavidyadhar23
I used Fusion 360 one time and the next time when I clicked on the icon, it wouldn't open, and no error message is displayed. I tried uninstalling it but it wouldn't uninstall. The task manager says it's running but the window won't open.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @meghanavidyadhar23 ,
Welcome to the Fusion 360 Community!
If task manager shows a running process, it will have to be killed before Fusion can be run again. Does restarting the computer cause task manager to not show any Fusion processes? Does it launch then? After restarting can you at least uninstall now without an error?
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
meghanavidyadhar23
Hi James
I'll try restarting the computer and uninstall. It could be a corrupt version as it has the .exe extension.
meghanavidyadhar23
Hello there,
Apologies for replying after so long, turns out it was a problem with the system and the windows version. I now use Fusion 360 on another system and it works seamlessly other than the occasional hiccups due to OS compatibility.
