multiples errors with fusion 360 on Macbook pro 16" m1 max running os 12.2.1
mhowey9532V7EL4
Message 1 of 38
mhowey9532V7EL4
Hello, i'm new to Fusion 360. i'm taking a class to learn the app and i'm on a Macbook pro 16" m1 max running os 12.2.1.
when i first open/launch Fusion i get about 12-15 errors they will not stop unless i send report which i do. they do stop for a bit until i start working in Fusion 360. the errors do not seem to occur with the same tasks other than on start up.
any help would be appreciated. thank
mike
Replies (37)
Message 2 of 38
RajkumarIlanchelian
@mhowey9532V7EL4 @Do you have any other Autodesk product especially AutoCAD? This could be a single single on issue that you are seeing.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 38
mhowey9532V7EL4
Fusion 360 is the only Autodesk app I have. I was wondering if it was the M1 max chip set?
Message 4 of 38
RajkumarIlanchelian
@mhowey9532V7EL4 @Let me look at our backend database for the reports you sent in. We do have many customers successfully using the M1 but could be other reason for this.
can you please do an uninstall and a reinstall of Fusion 360? I know this is not a typical solution but this could work in this situation.
please use the clean uninstaller in this article to uninstall - https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Autodesk Fusion
Join Fusion Insider
Message 5 of 38
mhowey9532V7EL4
@RajkumarIlanchelian, I did the unistall and reinstall the restarted the app and logged in. so far it's not giving me 12-15 errorrs, so maybe this was the fix.
thank you.
Mike
Message 6 of 38
mhowey9532V7EL4
@Rajkumar.ilanchelian, unfortunately I hit the solved button too quickly. After a total uninstall/reinstall Fusion 360 work, but i did not work in the app much yesterday. this morning I launched the app and again received 16 error messages.
any help would be appreciated,
Mike
Message 7 of 38
mhowey9532V7EL4
, hi, the confusing part is when i quit Fusion 360 the errors keep coming for a bit.
Message 8 of 38
j.maltekrueger
Hi at all,
same error here.
Bug report window keeps popping up every 5-10 seconds for 10-20 times. Happens when I launch Fusion on my Macbook Pro (M1 Max, macOS 12.2.1, fusion v2.0.12392), but also after a while when I start interacting with the app again, as well as when I want to close it. Even after having force quit Fusion, the windows keep popping up.
Clean reinstallation did not solve the problem.
This not only takes all the fun / motivation when you want to create some cool models, but it also disturbs my workflow on the entire Mac as the windows keep popping up in the foreground.
Cheers from Germany,
Malte
Message 9 of 38
mhowey9532V7EL4
I don't think Autodesk has an answer for us. sadly.
Message 10 of 38
RajkumarIlanchelian
@mhowey9532V7EL4 @j.maltekrueger We are actively looking at this and talking with our engineering team. I will keep updating this tread as we know more and I am asking for a workaround until we can fix a fix for this. We apologize for the experience but we are certainly working to find the right solution.
Autodesk Fusion
Join Fusion Insider
Message 11 of 38
j.maltekrueger
Sounds good for me. 🙂 Thanks for your effort fellas! 🙂
Message 12 of 38
mhowey9532V7EL4
we appreciate your help, thank you
Message 13 of 38
RajkumarIlanchelian
Can you please confirm if you see this folder?
1. /Users/USER ID/Library/Application Support/Autodesk - Do you see an AdSSO folder?
2. if you do see a folder how many sub folders are there? Can you attach a quick snapshot of the subfolders?
Autodesk Fusion
Join Fusion Insider
Message 14 of 38
j.maltekrueger
Yes, there's one subfolder (cache) which is empty, see screenshot
Message 15 of 38
RajkumarIlanchelian
Can you please try the below?
1. Close Fusion if it is running (Check in activity monitor)
2. Close any other Autodesk products that you have open
3. Restart your machine (This should not be necessary but I am asking this to avoid any assumptions)
4. Go to  /Users/USER ID/Library/Application Support/Autodesk - Delete the AdSSO folder
5. Go this this Article - https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/simplecontent/content/au...
6. Follow the instructions to install the AdSSO in there
7. now launch Fusion 360
Are you seeing the old experience?
Autodesk Fusion
Join Fusion Insider
Message 16 of 38
mhowey9532V7EL4
i had one folder listed AdSSo with one file within. i'm sorry i deleted it before reading your next message.
Message 17 of 38
RajkumarIlanchelian
That is fine. Can you install the one that is attached the article ?
Autodesk Fusion
Join Fusion Insider
Message 18 of 38
mhowey9532V7EL4
just finished removal and reinstall following instructions. i relaunched Fusion 360 and get the same amount of error, and the errors after closing the app.
Message 19 of 38
j.maltekrueger
Hey Rajkumar,
that actually solved the problem for me!
Both starting and closing the app doesn't prompt the bug report window anymore.
Thanks for your very quick trouble shooting, didn't quite expect such a fast response after you said "We're on it" 😛
Best wishes from Germany
Cheers,
Malte
Message 20 of 38
RajkumarIlanchelian
@j.maltekrueger Glad this solved the issue for you. This is a workaround with a true fix coming later but this should get you working. Please restart the machine one more and then launch Fusion to see if you are not getting back those errors.
@mhowey9532V7EL4 I am still wondering why this did not work for you. Can you try the whole process once again if you don't mind? If it continues not working, I may have another solution to try out.
Autodesk Fusion
Join Fusion Insider
