Multiple Users on Same Design
I am currently working on a rather large design, with no external linked assemblies.  While I tackle some larger changes to the design, I would like assistance from a designer to handle a number of smaller changes.
What is the best way to go about this without causing too much trouble for either user?  Will we simply need to tag team the design, alternating who works on it?  Or will this involve creating multiple sub-designs, and keeping them updated in some type of master assembly design?
Any guidance and suggestions appreciated, as I couldn't find much on this topic.  Thanks!
ryan.bales
Autodesk Support
Autodesk Support
At this time concurrent modeling isn't supported. you could both work in the same file but one of you will always trump the other on saved changes so you'll each be making versions that do not have the others changes.
So it would be best to have broken out sub-assemblies or designs to allow for each of you to work on different aspects of design.
Ryan Bales
Fusion 360 Product Support
