Moving a profile generates red error projections in a sketch downstream. There are two projects posted: "...before" has the User Parameter mainBallPathRadius set to 140 mm; in "...after" this is set to 135 mm. The drawing depicts sketch "Track support profile" with the red error projections. There does not seem to be a way to fix them as in "Manage Lost Projections".
I've tried creating two small extrusions of track to use as a projection template (verses the sketch). The bodies move if their underlying sketch shifts, but not the projected profiles.
I originally had everything crammed into one sketch, but that just created sketches with way too many constraints to be stable and lockable. This attempt to "do the right thing" by making simpler sketches and linking them via projections created another set of problems.
Any suggestions on how to improve my workflow would be appreciated. More info below.
The first (originating) sketch ("Track path centered") contains two rolling ball track profiles. The second sketch ("Track support profile") projects the track outlines and builds a supporting body into which the track is inserted. The channel needs an offset from the original track profile for ease of insertion. The Offset Face tool could be used, but these shapes may get complicated and selecting all the faces to offset is tedious and problematic... if it doesn't meet failure at the hands of the geometry engine demon.
thanks,
mark
