moving a sketch offset to a different offset plane
Hello
In the attached drawing I have a drawing of a locomotive wheel. I am trying to create spokes that have the same geometry around the hub. The spokes will have a gentle curve from the rim to the hub. I did try drawing the spokes on the vertical sketch plane but that meant different length spokes with different geometry depending on what part of the hub they connect to.
So I decided to try with a loft command. Drawing the spoke and then using the loft command to contour each spoke around the hub.
To create the contours I have drawn an offset sketch of the hub. This can be seen in the sketch.
What I now want to do is to try and move the offset sketch to a new offset plane closer to the top of the hub. this will form a guide for the spoke shape to follow.
Is it possible to select the offset sketch and move it to a new offset plane?
Many thanks in advance.
