- Mute
- Permalink
- Report
I inserted a machine screw from McMaster into a design.
I rotated the part 180 degrees around X to point it downwards, and moved it up a bit from the center-of-the model, so it's easier to work with. (There was no "capture position" option here, btw.)
Now, I open the move dialog, and move point-to-point, selecting the bottom of the screw head and the top of the screw hole I want to align it with.
The preview looks exactly like I want it.
Then I OK the dialog, and the part actually moves to a totally different position!
I pasted a screen capture of what I'm doing -- how do I make it commit to the correct previewed position when I select "OK"?
I would post the f3z archive, but "export to f3z" has been running for three minutes now and is about 4% along.
That's a separate problem, though -- I just want the screw to stick where I put it!
