I noticed an issue with parametrization of Move/Copy function. Steps to reproduce:
- Create an user variable in "Change Parameters" with corresponding length of angle units;
- Open "Move/Copy" dialog;
- Select an object, set pivot etc.;
- Set the created variable for distance translation or angle;
- The variable IS recognized and accepted;
- Click OK;
- The part IS rotated or translated;
- You'll see the created step in Design History;
- Now, modify the variable in "Change Parameters";
- Nothing happened;
- Edit the Move/Copy step in Design History;
- There is NO previously indicated variable!
Can anyone confirm this behavior? If it is present, would it be possible to fix this bug?
EDIT: This only happens in "Free move" move type. The parametrization in individual "Translate" or "Rotate" move types works well.
