Mouse scrolling not zooming in/out after January 2025 update
zack_sybert
Message 1 of 8
zack_sybert
Just encountered this issue after the last update which was in January 2025. Immediately after updating my mouse scroll wheel stopped zooming and instead started scrolling. Very annoying and time-wasting. None of the aforementioned solutions worked for Windows. This is most definitely a bug.
@zack_sybert Moderation edited title for clarity.
Replies (7)
Message 2 of 8
lance.carocci
Please try unchecking Use Gesture-based View Navigation under the General section of Preferences.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 3 of 8
HughesTooling
Check your settings in preferences. On one of my PCs the setting was changed from Solidworks to PowerMill with the last update.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
zack_sybert
I unchecked 'Use Gesture-based View Navigation' and it fixed my problem. Thanks!
Message 5 of 8
geoffX2HF7
Observer
Observer
Thanks for the solution, and no thanks for changing basic behavior without warning. UI people never learn.
Message 6 of 8
timangus
Just to add another data point; I use RDP to access a Windows installation from my main computer which runs Linux (because Autodesk refuse to port it to Linux, for some reason). A recent update to Fusion resulted in the mouse wheel simultaneously zooming and scrolling, making it virtually unusable. Disabling "Use gesture -based view navigation" has fixed this for me. Oddly, if I accessed the Windows machine via VNC, it didn't exhibit this behaviour.
Message 7 of 8
Pylonbob
Unchecking Use Gesture-based View Navigation under the General section of Preferences worked for me thanks. The other problem I had with this update was that it removed my 3d printer, took me a while to realise what had happened to it
Message 8 of 8
wnsdl0506
Community Visitor
Community Visitor
Very Thanks for infomation, problem solved after turn off gesture navigation option. Why Autodesk change setting without any warning? this is very irritating
