Hello: I am designing a new type of machine and have assembled various components. When I assembled same I used the "Rigid" option. I now need to change the movement to "Slide" or "Revolve". I that possible in Fusion 360 or do I need to start over? Thank you for your help.
Normally you can simply change the type of joint but it really depends on the assembly. Can you attach it to your post? Open your model, select the File menu then Export and save to you hard drive. Attach it to a reply post.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
