Fusion Support
More New / Old Bugs with latest update.
9 REPLIES 9
Message 1 of 10
badonj002
272 Views, 9 Replies
Having fun with us?
9 REPLIES 9
Message 2 of 10
badonj002
in reply to: badonj002
Restarted, another update, still broken
Message 3 of 10
g-andresen
Please share the file for investigation.
File > export > save as f3d on local drive  > attach it to the post.
günther
Message 4 of 10
badonj002
in reply to: g-andresen
ok
Message 5 of 10
badonj002
BTW, exporting the files and opening them in Simplify3D and exporting as a STL combines them, then having to open it up in Microsoft's 3D Builder to repair whatever Fusion is doing like it is 6-Years ago.
Message 6 of 10
TrippyLighting
I think before reporting a bug you should learn to observe what is happening in your model and then change your modeling approach.
Properly modeled this is not a problem.
Peter Doering
Message 7 of 10
g-andresen
If the contours are aligned with the axis of rotation, there is no problem.
günther
Message 8 of 10
badonj002
There should not be a problem at all for any reason. It is not what fusion 360 wants me to create, it is what I want to create. It was fine, then it was not? That should not matter at all. This bug work-around stuff is irritating. If I can do  Join operation when creating an intersecting body and it works, then I should also be able to do a combine.
I recreated the project like I have to do with most projects, and worked. Just had an issue where a profile would not extrude after timeline change, and I had to delete it and recreate it? Sometime I have to save, close fusion, then open fusion again to get it to work?
Everytime I post on the forum, then I get up-to-date at launch. Then when I close it, it says update available. I select not to update, and it updates anyway. WHY ASK? This bs is getting old. Every single time.
Do people actually pay for this? I guess they do not have these problems because they have a login that says don't beta the paying customers. If I needed to buy a 3D Cad program for a business, I would buy something else.
Message 9 of 10
g-andresen
If you don't understand an answer, ask instead of posting any confusing description
günther
Message 10 of 10
TrippyLighting
@badonj002 is there a possibility - even remote - that you can consolidate your multiple posts into something more cohesive backed up by data, so we might try to help ?
If you want to share your design privately and explain in a sentence or two , or perhaps even a screencast and explain what is going wrang, I'd be happy to look at it. I have zero interest in the IP of your designs.
If that does not interest you, then you can stop posting. No one from Autodesk is going to respond to it and quite frankly if I'd be an Autodesk employee I would not either!
Peter Doering
