Fusion Support
More joint positions on one drawing
3 REPLIES 3
ales.lucanik
600 Views, 3 Replies
I want to ask how can I create drawing of assembly with more different joint positions. For example imagine that you have assembly of folding knife and I want to create drawing with 2 views where on 1 view knife is folded and on second is open. As far as I know only one position is now possible for all views of one component/assembly. Or am I doing somethin wrong?
Thank you.
3 REPLIES 3
jhackney1972
in reply to: ales.lucanik
Please excuse my crude model but you did not supply yours.  The process is pretty simple, just copy and paste new the blade component and show it in different joint position.  Create your drawing with two unique entries and suppress a component for each blade position.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
ales.lucanik
thank you for your feedback. This way I know but it is more like way around and if you have bigger assemblies with many joints it requires a lot of double work. So generally right now there is no function which would allow you to set different "positional representations" for assembly. Perfect would be if you set required values for your joints and then set it as representation A, then adjust joint values and save it as representation B. After that in drawing you could choose desired representation of component and you don’t need to care about coping and suppressing of parts.
I am experiencing the same problem. The work around is ok, but with more than a handful of joints it can become a real problem.
