Announcements
Modify - Align
amach645
Observer
Modify - Align
amach645
Observer
Observer
I have an insert Molded part that consist of about 3 inserts and a plastic housing (4 bodies) that I need to move to the drawings Origin using the Modify Align feature but it never works.  I can move all bodies but not align all bodies at the same time.  I even created a selection
Capture.JPGset and it still does not work.  Any suggestions
jhackney1972
The best method of positioning bodies is to turn them into Components and then use Joints to assembly and place them relative to each other.  You can do it with Align but it is a lot harder especially with 4 unique bodies. It would help if you would attach your model to a reply Forum post.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
