Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Model Suddenly Transparent
2 REPLIES 2
infoH94RN
252 Views, 2 Replies
I am using the free version of F360.
I edited a 2D sketch that was the basis of a 3D body.  When I completed the edit and returned to viewing the body, it and the entire model had suddenly become transparent, and I can't change it.  This is happening in the "Design" space.  In "Render" the model is opaque.
Physical Material is set to Walnut, Appearance is set to Dark Stain, Opacity is 100% and it does not matter if Active Component Visibility is checked or unchecked.
I have attached the file for your review.  I truly hope someone can help me as I am rather stuck.  Not only is this version of the model affected, but all prior versions of that model.  In addition all of the previously created models that I have checked on have also been affected.
2 REPLIES 2
jhackney1972
in reply to: infoH94RN
If this is what you mean by Transparent, then select one of the other settings shown.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
infoH94RN
OMG!  I'm so grateful!   I've been trying everything I could think of for hours.  Had no idea that feature even existed (and even less idea what it would be for).  I must of hit the keyboard shortcut, ctrl-7, when I was aiming for ctrl-Y.  I'm saved!
