Model Representation
connorTSF4Y
connorTSF4Y
I would like to change my model rep between the full assembly and an area I am working on. Is this possible.
Turning the visibility of each item on and off doesn't cut it and it is time consuming.
Also when creating a drawing, can I select parts of the assembly without having to turn all of the parts i dont want off
g-andresen
Show this process in a screencast.
NO
günther
jhackney1972
Fusion 360 does not have View Representations but you can get a little closer to what you want by using the Isolate and Unisolate command.  Take a look at the Screencast.
John Hackney, Retired
