Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Model errors, after plying design history, missing parts
1 REPLY 1
karimgrase
191 Views, 1 Reply
after plying the design history, it appears that bodies are completely misaligned, and some parts, bodies are missing at a certain design step?
I tried to repair some of the yellow flagged sIso view.PNGsideview.PNGteps but with no success.
Any advice how to repair the model is appreciated, otherwise i have to go back to an erlier model version.
enclosed some views of the situation.
thanks,
Karim
Labels (1)
1 REPLY 1
karimgrase
in reply to: karimgrase
OK, i have solved the problem,
i did upload an erlier version were the parts are aligned, i found the the sketch which used a wrong offset point, so i did re associate the sketch in to the correct center point and rerun the design history.
Now everthing is fine again.
cheers,
Karim
