Missing Sketch palette
vilhjalmurm
vilhjalmurm
Hi I am a Fab Lab manager using and teaching Fusion 360 for over two years. Recently the "Sketch" palette in Fusion 360 has disappeared from the main palette in some of our computers We have  tried to sign out, sign in again, restart the computers and so on! Any idea why that happens?
HughesTooling
Have you tried right click on the menu bar and select show hidden panels? Also can you use the Photo option to include your pictures rather than attach, I haven't looked at you attached picture because I'd need to download to view then delete and can't be bothered.
Mark
Mark Hughes
Owner, Hughes Tooling
vilhjalmurm
Thank you I could fix the problem with the right click options on the Menu bar 😉 Thank you very much!
Best regards Villi
MariusBaard
Thanks Hughes, but why is that happening?
Is it a problem they will sort out, ore are we doing something wrong?
MariusBaard
Show all hidden not working, grayed out
HughesTooling
@MariusBaard the problem you're seeing is different. See this thread.
Mark
Mark Hughes
TopHound
Well I tried everything with no difference. Quit Fusion 360 and went back to other tasks then came back to have another look again this evening... and its working again!  Thanks for your help.
