Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Missing Sketch Lines in Fusion 360 When Importing a STEP File
3 REPLIES 3
fsafor8
135 Views, 3 Replies
I NEED HELP
I have a step file that only has lines (sketchs from another cad program) in it, when i try and import it into fusion 360, the lines do not show up.
The sketch is a 3D-Sketch
I have attached the fils i you want to try them for youself
Tags (3)
3 REPLIES 3
TrippyLighting
in reply to: fsafor8
You will need an Addin to do that!
https://github.com/kantoku-code/Fusion360_Curve3D_Doorway
fsafor8
in reply to: TrippyLighting
Thank you i will try that
fsafor8
Thank you very much, it worked !!!!!!
Technology Administrators
