Missing Qt6Widgets.dll
schultz.rick2
schultz.rick2
Anyone have success fixing or replacing a missing Qt6Widgets.dll file?
I have been having some weird connection errors while working online.  Randomly Fusion will drop its online connection and usually comes back on.  I have tested my network and I can say that the issue does not appear to be with my actual network as its running as it should.
last night I had the problem and I was not able to reconnect. I went a chose repair fusion from the dashboard.  The repair process failed and I lost the Qt6Widgets.dll in the process.
Now I am unable to launch Fusion. When I attempt to launch fusion I get the missing dll file error and a suggestion that reinstalling Fusion may fix it.
the screen shot of the error is attached.
what is the correct procees to fix this problem?
Thank you,
Rick
g-andresen
might help
günther
schultz.rick2
Will uninstall effect file data and team member connections?
pdifflipp
I am having the same exact problem, it was running fine yesterday afternoon, now this morning I am getting the Qt6Widgets.dll window
schultz.rick2
@pdifflipp
As others have suggested,
I would try uninstalling fusion and reinstalling fusion. It worked for my situation. There are a few hidden files that may need to be deleted after the uninstall, prior to reinstalling fusion.
I believe there are posted links to resources posted earlier in this thread.
If you cant find those I would follow the Autodesk guidelines for uninstall and reinstalling.
Rick
pdifflipp
Thanks, Rick!
I did try uninstalling then reinstalling but received an error message while it was installing. I posted the log file . I am guessing I might have a permissions problem because of our IT department.
Thanks again, Paul
schultz.rick2
Yea if you have an IT department I would have them help you though the
process.
I have a single seat license for my small shop. No IT department.
